P
pencilpusher
I am changing my consumer unit from a 16th edition to a 17th edition one.
I have a question about testing the new CU and its certification. All circuits will be additionally protected by RCD's or RCBO's except a distribution circuit to my detached garage. This is run from the CU in SWA for about 4 meters to the garage 2 way CU and is then protected by an RCD in the garage. I presume this is OK otherwise I would have the circuit protected by an RCD at source and then protected again in the garage with another RCD and I will struggle to achieve discrimination??
My question relates to the EIC for the new CU. What tests need to be done on the SWA out to the garage CU. It will be protected by a 16amp CB at source. Is R1+R2 done on the SWA leading to the garage CU? How about ZS and how is that measured and from where? My thinking is that the ZS for this circuit will be Ze + (R1+R2) of the cable from the CU to the garage CU but before connection to another circuit??
This is for my part P assessment but this is causing me a bit of confusion.
I am fine with the testing of all circuits fed from the new CU except this distributiion one. Any advice would be gratefully received.
PP :juggle:
PP :juggle:
