Testing of rccb's | on ElectriciansForums
Discuss Testing of rccb's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
V
vamsipenu
iam using 32A RCCB's .
i would like to test it weather the test button operates it properly
pls suggest me how to do it
Pressing the test button would be a good start!!! lol!! If it trips the RCD then it's working..
To fully test the RCD unit you will need an electrician with the appropriate test equipment to test your RCD.
The test button test, is just a very basic test which only tests the sensing coil (to some degree) and the mechanism...
Please tell me it's killing me. Too many Singa beers. Anagram?
Spivamenu?
I noted the other day a chap had rearranged the letters on his escort van to read
"scrote"
ok - I was thinking it was some kind of wind-up and misread the name as an 'anagram'. Thought I was reading it backwards but was reading it part backwards, part forwards, part backwards. Thought it said u-penis-mav when read backwards. My mistake. But it was a pretty inane question by the OP.
Agreed! Maybe he or she was having a blank moment... I get them !!!
Reply to Testing of rccb's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If it’s rcbo’s, then it’s 30mA per circuit… an rcd mainswitch is 30mA for ALL circuits It may just be a cumulative earth leakage which was just...
Most RC Model systems work on a bus system now days so minimal wiring, Transmitters are available up too twenty channels and more so that is not...
