Yeah well, sometimes I do that.
Then again, you still haven’t explained what it is you disagree with Tel about.
I think I have.
So do you disagree that it’s acceptable to test at the light switch, or do you disagree that the test should be at the out going terminals of the RCBO with everything disconnected?I think I have.
That is a lot of faff when , As has been stated, you are testing the circuit to the accessory to check the functionality of the RCD part of the RCBO. Now a ramp test is different and would warrant disconnection.Also I think some rcds / rcbos actually need short pieces of cable on the load side to get a reading.
Here's one of them aforementioned debates;
RCD Test on lighting circuit protected by RCBOs - https://www.electriciansforums.co.uk/threads/rcd-test-on-lighting-circuit-protected-by-rcbos.114565/
Read it for me Middy and give the bare bones - I can’t be bothered and you seem to have spare time on your hands!
Reply to the thread, titled "Testing RCBO at Light Switch" which is posted in ElectriciansForums.net News and Updates on Electricians Forums.
