B
Bonse
Hi People
So im testing my ring rinal circuit....
i do my end to end test.....
I join incoming CPC to outgoing Line and vice versa......
I then go around my circuit with my tester noting the readings at each socket and record the highest reading.....
Ok so this is my R1+R2 = 0.3
My measured Ze is 0.17Ohms
So my Zs = 0.29 + 0.17
Zs calculated is = 0.46....
Ok so now i reconnect the line and earth in the terminals and liven up my circuit (I have already done the insulation resistance also sorry didnt mention)
Then i goto the socket i got the highest R1+R2 at and do my Zs....
I get a result of 0.31Ohms
Can anyone explain how this is possible?
If Zs= Ze + (R1+R2)
How can i get such different results between calculated and measured?????
Spoke to my friend who has been around a long time and he tells me he does his R1+R2 at the consumer unit.... even though in the OSG it says the way i did it was correct.
When i do it his way i get slightly different readings but they still do not work out in the end....
The circuit is otherwise sound.
Im really looking forward to the replies, oh and yes the leads were nulled
Darren
If Zs= Ze + (R1+R2)
Darren
