Testing Ring final circuits | Page 2 | on ElectriciansForums
Discuss Testing Ring final circuits in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I said bonding not main protective Conductor
thanks for the input like i said i just wanted to get the result as calculated. as a lot of sparks will calculate and be happy with the result
basically the answer is parallel paths....
The fact that the Zs is lower than Ze + (R1+R2) is fine on the test certificate.
Thanks everyone much appreciated!
That's about it, a competent person reading the test results would expect that scenario.
Correct, and in actual fact if the Measured Zs recorded on the SOTR was equal to the recorded Ze plus the recorded R1 + R2 then a competent person checking your results would be very suspicious of your R1 + R2 readings. He would probably suspect that they weren't resistance readings at all. ;0)
Lol, but do remember that in accordance with Guidance Note 3, calculation of Zs from Ze+(R1+R2) is acceptable
So to eliminate parallel paths a calculations probably better, or do both and if he measured result is less than the calculated it can be down to parallel paths whith is acceptable
All good stuff guys!
Be reading GN3 again!
Reply to Testing Ring final circuits in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
