Testing smoke alarm circuit | on ElectriciansForums
Discuss Testing smoke alarm circuit in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
P
p11jor
Hi all, does anyone test there smoke alarm circuit, just first fixed a full rewire so have put the interlinked smokes in....just having another confused moment about this!
Surely for a functional test, activating one of the alarms by using let's say lighting a match underneath and blowing it out will activate the detector. Then it's a case of making sure that all the alarms are audible at the same time...
Yer I would be doing a continuity test, the ir tho would just shoot the 500 down the line and neutral so the three core one conductor would miss out......would I go to the first smoke disconnect the three core and start another from there between all three and the cpc? I am well confused,
Smokes are sensitive, you sure you wanna make them swallow 500V ????
End to end continuity for each of the conductors (including the extra signal cable). Then you have some options to test for IR. You can do LN->E and LS->E for example.
Remove smokes and replace with connector blocks so that the entire circuit is complete and stick the 500 V's up it :D.
IR all conductors Live Neutral, Live CPC, Live Switched Live (signal) Etc etc etc
As for functional testing, use the test button and there is such a thing that you can purchase from the wholesalers called "A can of smoke" I thought I was having my leg pulled when it was first mentioned but it is true :)
Much better option to use the connector blocks! :D
Reply to Testing smoke alarm circuit in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
