Testing | on ElectriciansForums
Discuss Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Do you have to test every job you do?? Even if it a like for like change like socket or light??
its important to test after you have done a socket to prove your Zs (earth) and your polarity and if you provide your customers with a certificate it makes you look very professional
Reply to Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
