Testing | on ElectriciansForums
Discuss Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
O
ONIT
Afternoon,
Looking For A Bit Help, Changing A Light Switch For A Dimmer Switch/box Bedroom One Light-one Switch.
With A Minor Works Cert, What Tests Would Be Needed (were Do You Start And How Far Do You Go)
All Replys Welcome Cheers
if you doing a minor works for this (and i am not sure that i would)
Do R1+R2, but you will probably have to short out the dimmer, while its shorted out, do IR, then do Zs, then reconnect it
Thanks Shakey,
I Was Thinking Of Disconneting Switch Doing Ir On Switch Wire Then Reconnecting And Doing Zs From C/rose Got Niceic Coming
you might have difficulty doing Zs through the dimmer, your meter may not pull enough to trigger the triacs in the dimmer, and even if you do, it may give you a high reading - but give it a go!!
Any Ideas Of What Tests Niceic Would Be Looking For, For A Replace Ment Of A Dimmer
Reply to Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
looks like the OP has disappeared which is a shame, would be nice to get to the bottom of this.
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
