testing | on ElectriciansForums
Discuss testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
tes11
wiring 2 new flats can i sign test sheets/certificates i am qualified approved electrician :confused::confused::confused::confused::confused::confused::confused::confused:
Not to be funny mate if you are approved why are you asking such questions?
if you are with one of the approved companies Nic Napp and the rest, then you can sign of your own work .
yeah no problem testing do all the time at work then hand in test sheets wiring flats for my brother wasnt sure about signing certificates also where can i get hold of set of test sheets thank u
or you can buy from wholesalers or ebay. fluke, kewtech and others do them, around ÂŁ18 for a book full.
Reply to testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
