Texecom Premier 24 - problems? | Page 2 | on ElectriciansForums
Discuss Texecom Premier 24 - problems? in the UK Electrical Forum area at ElectriciansForums.net
L
ljt-electrical
Hi there, I've installed quite a few of these often have to ring tech support because the menu is that intense you forget everything you need to no lol.
Problem 1 = when I walk in the entry exit (door contact) the pir insight of the keypad picks me up but I have set this to guard access but alarm still goes before I have managed to disarm the system.
Problem 2 = when I walk in the entry exit and go straight into a guarded area yes the alarm goes off but sound only comes from the keypad instantly and then if you leave it going off for 30/60 seconds the outside bell then goes off. I have looked in menu and saw something about a bell delay but thats off.
Hope someone can help me.. Cheers
I always set all my systems to normally closed. Never had a problem just need to no why the pir in view of the entry goes off when Ive set it to guard access and I've never had a delay on the bell aswell and I've fitted a few of these
on door contacts normally closed is wired across A & T with no tamper circuit at set to NC, if wiring across A for alarm & T for tamper, then this is Double Pole, change setting to Double pole/EOL. (which is default setting)
This is basic wiring, and is fully explained in the manual.
Reply to Texecom Premier 24 - problems? in the UK Electrical Forum area at ElectriciansForums.net
I don't fit alarms as my main job but have fitted quite a few over the years whilst we were doing the electrics side of things. I usually fit the...
