Guest viewing is limited
View the thread, titled "The big difference in the electric terminology and installation regulations and practice in each country!" which is posted in Talk Electrician Forum on Electricians Forums.
Going back to my dad's time pre-war, an apprenticeship lasted 7 years, the first 5 were spent with one firm, the next 2 were split into 4 x 6 month periods with 4 different firms, where you learnt the things not done in your own firm, those last 2 years you were called a journeyman, this was before apprentices had to go to collage, it was considered when day release was started that the apprentice would gain this broading of his knowledge in collage and the journeymen stopped in the UK. Also it has been for many years that you finished your apprenticeship at around 21 years old, so the 7 years started at 14 years old, by time I started you did not leave school until 16 years old so to finish at same age the apprenticeship needed to be shorter. Now leave school at 18 years old, so instead of day release we have block release in collage, so apprenticeship even shorter.
Being frank I spend a lot of my apprenticeship as a skivvy, doing fetching and being cheap labour, my wife as a hair dresser had to pay to be an apprentice, and learnt how to wash hair. So likely the collage block release does teach more than the old apprenticeship.
The other thing when watching a YouTube video from America/Canada is all the cables are sized by ‘gauge’. The lower the gauge The bigger the cable.
I still want to know what a master electrician is compared to a journeyman electrician...
can you be a master journeyman....
and what the heck is a pony panel
Journeyman is a very old term, it originates in Europe as far as I know and describes someone who has served an apprenticeship under a craftsman but not yet become a master craftsman.
As far as I know Journeyman electrician is roughly similar to Electrician in the JIB scheme, with master electrician being roughly similar to approved electrician in the JIB scheme
I believe in the US an apprentice becomes a journeyman when he qualifies, then becomes a master electrician once he has enough experience. I think the master electrician is similar to the JIB approved electrician grade.
I believe this mirrors the way trade apprenticeships worked in this country hundreds of years ago.
Dave in the US you have to have 14,800 primary hours which means being superintendent on jobs then you have to take the masters test. We have guys and girls that can get low voltage license which is under 24vac,swimming pool license, limited license, intermediate license, and of course the Masters license
We also have Ring Circuits that are only really a U.K thing apart from a handful of Asian country's.
In the rest of Europe I think they use more Flex or single core cable the single usually in a flexible conduit.
In large scale events, In the UK and EU we use a connector called power lock for our temporary installation supplies rated at 400A and 600A (single pole (5 connectors for 3 phase))
Having worked a lot in America you guys use cam lock connectors which like power lock are single pole and rated at 400A
I struggle to understand why they are still allowed & used as they have the potential to be very dangerous: For these reasons:
  • Non-locking
  • male to male adaptors
  • T adaptors
  • Any colour can be plugged into any other colour
  • Very large exposed conductors easily touched when unplugged
Powerlock is: locking, will only allow phase to phase or earth to earth connections etc, and has no exposed conductors
I have even seen on TV shoots in the US where camlock is used on a public street and tee adaptors are used as joiners so the side outlet is not used leaving a live exposed conductor on a public pavement.
Although this isn’t a difference in domestic it still might be of interest,
Camlock Tee
Cam lock
Powerlock
  • Non-locking
  • T adaptors
Camlock Tee
Cam lock
Powerlock
Marcus I don’t mean no harm but I have no idea what you are saying. If you are talking about lock out tag out a person could lose their job if they don’t follow the correct procedures.
No was not talking about lock out tags,
was mentioning observations in how power is supplied for events, in venues in the US (what we meed to plug into)
its basically the same as me saying alot of countries use different plugs, but this one in particular I cant understand for the main fact you can get male to male connectors
maybe it is the wrong place to mention it, if so sorry about that, just find it interesting
No the "cam lock" is the make of connector.
Not quite as stupid a design as the 1/4" jack or phono audio connectors where the signal mates first and ground last, but at least they don't try to kill you! (OK, thy might kill your speakers if volume is up high when changing cables, but that is significantly less serious).
in domestics, we generally use twin& earth cable. :
hot wire we call line(brown) . neutral (Blue), and what you would call the ground wire, we call it "circuit protective conductor (cpc). OH, and due to some silly farts back in the 1970's all our cable is metric.
that's a start
Actually a good thing that was introduced. Was to avoid massive blunders happening in the scientific community where conversions would be made from old imperial measurements to metric. Everything from engineering/satellite's/chemistry (all relatable to electrics).
rubbish. if i see a measurement in inches, i can visualise it. if in cm, then i need to work out 25.4 = 1", so,say, a 25 measurement is stated, but it does not tally. it's 10" less a bit. also,e.g. my tappets on my van engine should be 10 thou. i set at 0.25mm and they rattle.
You and what you are talking about is at the very bottom of the ladder so to speak and you seem to have no understanding of how imperial v metric effects the world around you.
When you start venturing across the fields of physics for instance everything is relatable from a small piece of wire in a satellite to numbers you can’t even count in distances for instance. When you start using physics at the level of powers, conversions matter and mistakes can be made quite easily. When calculating the number of brain pathways in medicine it matters, engineering computer chips it matters.
Scientific units mass (kg) for instance can be a pound of pork scratchings but it can also be used to calculate how to get a spaceship out of orbit. So you have to have harmonised measurements across the board for reasons other than your spanner in a tool box.
Maybe we’re at an advantage, us older members who learned about metric at school, but still had old imperial parents.
We were taught both, and the conversion processes.
You can see how imperial lengths came into being… an inch was the width of your thumb… a hand was basically the width of your hand… used for measuring horses… a foot being self explanatory,
In those days we weren’t building massive skyscrapers, sending rockets to the moon or looking at micron sized particles through a microscope…
We didn’t need that level of definition, so we didn’t use it.
If an engineer or an architect can’t tell the difference between feet and metres, then they’re in the wrong job…
Totally agree but it still happens.
Here’s a list of some interesting stuff that has gone wrong over the years.
Reply to the thread, titled "The big difference in the electric terminology and installation regulations and practice in each country!" which is posted in Talk Electrician Forum on Electricians Forums.
