That’s a “Giant Plug and Socket”
It’s a plug, when coupled with a socket, but a plug top when talked about on its own.
has anyone ever used the term "commando plug top"? i think not.
Do you mean 3phase plug tops?has anyone ever used the term "commando plug top"? i think not.
Or the big Blue oneIs that the big Red Plug Top![]()
Is that because you are a ships master?I just knew someone would bring up the mass debaters line!
No. It is a plug for a bath (you would need to quote the size in mm).
It is a plug for an electrical device (you will need to quote the size 5A, 15A, 13A etc and the fuse value if the latter).
So E.G. I need a 35mm plug for my bath, preferably white.
OR. I need a 13A plug with a 5A fuse for my table lamp.
Me too but some Electricians aren't very bright.I'd always fit a 3 amp fuse for a table lamp.
