Guest viewing is limited
Dustydazzler
plug top or just plug
This one will appeal to George. Today, I was getting incorrect counts on a timecode generator that is driven with biphase from an optical encoder. Scoped the biphase lines and they were all over the shop. Checked the +5V supply from the box to the encoder, there's 100Hz ripple on it which is mucking up the encoder operation.
It's an American unit, which I am powering from the 230V mains here in Estonia, via a step-down autotransformer. Hmm, I thought, maybe my step-down is giving too low a voltage for the unit, causing the DC rail to drop out of regulation. Let's see what the supply voltage is, and what it is supposed to be.
Transformer output rating: 110V. Actual: 115V
TCG rated operating voltage: 115V
So, no, nothing to do with 110V vs. 115V vs. 120V. Actually, a bona fide failed capacitor in the power supply. It's working now.
It appeals to me too but not for voltage related reasons - what equipment were you working on? We have a lovely Rank Cintel MKIII telecine that kicks out biphase to sync to an Albrecht MB51 sound follower.
Sorry Lucien, for once your talking total -------s. Here's a better explanation;
ther is a plug top and a plug bottom. it's the bottom that holds the terminals and the top that keeps fingers out. in it's entirity, it's a plug.
Would you class the bit that holds the cable the 'plug middle'... or am I just being thick again....??
"The Great Debate" - Plug Top or just Plug?
Dustydazzler,
static zap,
