The hood kitchen goes into on/standby mode when I plug in the espresso maker! | on ElectriciansForums
Discuss The hood kitchen goes into on/standby mode when I plug in the espresso maker! in the Talk Electrician area at ElectriciansForums.net
Middle East
Hello,
The hood kitchen goes into on/standby mode when I plug in the espresso maker(I don't even turn on the Espresso maker).
What is causing this problem?
[ElectriciansForums.net] The hood kitchen goes into on/standby mode when I plug in the espresso maker!
Does it happen if you plug the espresso machine into a different outlet?
Does it happen if you plug something else into that outlet?
Strange place to have an outlet… above the gas burners….
And, I’ve got the same glass plates…. That’s weird.
Thank you, Could it be due to interference between electronic components in the espresso machine and the touch hood keyboard?
It could be that the coffee machine has a mains filter (including capacitors) across the power input before the on/off switch, and the act of plugging it in creates EMC interference (a spike) that upsets the cooker hood controller. I don't think it's necessarily anything sinister.
The options are:
Put the coffee maker somewhere else on a different circuit.
Leave it plugged in!
Put an interference suppressor on the power input to the cooker hood (or at least try one - it may or may not help!)
Reply to The hood kitchen goes into on/standby mode when I plug in the espresso maker! in the Talk Electrician area at ElectriciansForums.net
The ideal solution would be a 1 or thereabouts ohm NTC thermistor rated at say 10 or 15Amps. It would get hot so you'd have to have it safely...
If in doubt, hit it with a hammer and see if it gets better. sometimes the simple solutions are the best ones!!
