The phantom doorbell!....... | Page 2 | on ElectriciansForums
Discuss The phantom doorbell!....... in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
Called to a small job this morning, woman in her mid 40's says her doorbell is not working properly...
says it keeps going off but nobody is at the door as she can see the front door from her kitchen window.
So I arrive and check it over. The switch is in good order and the wires go all way back to the consumer unit, however it then gets a bit weird the wires are not even connected into the consumer unit anymore and are tied up next to it. the transformer is sat on top the shelf next to Cu covered in dust and grime and has been for some considerable time looking at it.
No voltage at all on the bell wires.
She is adamant she can hear the doorbell going but how do you tell her its all in her head! there is no doorbell and the old one is not connected!
Not one to make light of peoples mental health issues but she is clearly not the full ticket. Charged £20 for my time rather than usual call out fee as I didnt do much apart from put a blank plate and membrane grommet in the CU to fill a gap, dont want her poking inside.
For some reason i keep getting calls that in all honesty should be going to social services.
Sounds like another spark has been called in for the same reason and decided to dis-connect the transformer and maybe left it at that, some time ago by your description. You do seem to have an over the odds colourful customers call out rate considering your Bristol call out for the distressed lady in stapleton was it?
yes, staple hill just off the high street. It seems to be my interesting customers are all over your way @Vortigerm I swear the ring road is becoming a line that you cross at your peril.... stick to gentile bath folk...
Something about this woman makes me think that shes got issues, just an instinctive feel. In anycase there is no doorbell, her neighbours have no doorbells. and there is only one property either side.
“Not the full ticket” never heard that one but it’s sort of a polite way to say it. You sure she’s not just lonely and making it up for some company?
This reminded me about a job I went out to once a good while back. Turned out that I had been recommended to this lady through a friend of a friend... When I got there she said that she had got a leaky tap under her kitchen sink and asked if I wouldn't mind taking a look. I got down under the sink and couldn't find a single leak or even any evidence of there ever being one. She remained adamant that there was a leak, so I tried filling the sink, testing the overflow, the waste outlet... nothing, dry as a bone. So I just politely told her she might be mistaken and it must have been a spill, or leaky container and left.
I found out a few months later that she was a single lady who was lonely and she had a thing for "builders bums" apparently she may have tried to / or taken a picture of my backside while I was bent down with my head under the sink. :D
A few years ago I fitted a new doorbell, wireless...
It rang randomly, and eventually I discovered my neighbour across the road had bought a similar one...very annoying that when they had visitors, our bell rang.
A quick flick of the micro switches inside sorted it.
Once upon a time, my doorbell was a bell that was wired to a switch on the outside of the doorframe, powered by a 1289 battery...it worked fine for ever...
Progress, eh?
Progress, eh?
I once fitted a door bell consitsting of a PP9 battery bell push and a transitorised buzzer, got called out to it 18 years later, not working due to bell push corrosion, and had to scrape the push again after another 8 years. How long would a modern fancy one last?
years ago, went to a customer to carry out an annual service on the intruder alarm. nice new uPVC door and frame with a shiny new brass bell push. pressed the bell push ( as you do) and got the worst belt i've ever experienced. keys in my hand went over into next door's garden. investigation found the the door fitters had not noticed that the old bakelite push had 240V going through it. so fitted customer a ELV battery bell. ever since then i've pressed a metal push with a VDE screwdriver.
I think it's time to open a huge can of worms…lol. It is possible to pick up electromagnetic radio signal depending on the type of dental fillings someone has and the arrangements of those fillings inside the mouth. The ears can pick up that signal and turn it into sound.;)
That's one way to keep the cold callers away from ringing the bell.
Reply to The phantom doorbell!....... in the UK Electrical Forum area at ElectriciansForums.net
However it's done, you need to have a guarantee of no sharp/unprotected edges that can damage the insulation. Personally, I'm not that impressed...
