Spoon
Mentor
I was just reading an interesting post about the 18th when the above was mentioned. there seems some debate about this. I initially thought that the idea of prohibiting the use of them was stupid, but I'm not sure now.
http://www.swaonline.co.uk/files/ww/Install Protect _ ComplyFull Document.pdf
These walldog screws look like they could strip the hole easily in some cases.
I'm wondering about another couple of scenarios that don't seem to have been covered here:
- Cables in loft or basements that are only entered for building maintenance - are these spaces included in 'metal fixings must be used everywhere'?
- Cables fixed to exposed wood (e.g. skirting board, exposed ceiling timbers, or in a garden shed). Everyone seems to assume all walls are made of solid concrete which is actually rather rare in domestic settings. I have used metal clips fixed to wood and believe the wood would take longer to burn than a plastic, but I don't know how much longer or how the regs would apply to this.
This is why we have amendments, so they can make new book for more money. Blue, green, red, yellow etc. lol.
I'd go with Yes, as I presume that firefighters would have to search every room, in case of a fire.
"Sorry about the body in the basement, but as it was a maintenance area I thought there would be no one there, so we didn't search it." would not go down well..
If the cables can't fall down because their failed, how can someone (or a fireman) become entrapped in them, thereby falling (forgive the pun) into the interpretation of said definition?
Like, hows a cable clipped to a skirting, gonna entrap a fireman?
Interesting point, but I wonder whether in practice firefighters crawl through basements so small they cannot bend their knees, in burning buildings, on the one-in-a-million chance there is someone in there. If not, then where is the cut-off?
OK bad example on my part, maybe a cable clipped to a dado rail (if anyone's ever done that)? That said, I don't think cables clipped to skirtings are excluded, unless the cables are actually supported by the floor. Perhaps a cable falling away from a skirting could at least become a trip hazard?
Here are the clips and raw plugs I have been using in escape routes - looks like I'll be getting through more of these:
https://www.screwfix.com/p/d-line-s...ps-for-2-core-1-5mm-fp-cable-pack-of-12/90366
https://www.screwfix.com/p/prysmian-ap9-white-clips-pack-of-100/33690
https://www.screwfix.com/p/rawlplug-metal-wall-plugs-6-x-32mm-50-pack/9584p
https://www.screwfix.com/p/fischer-self-drill-plasterboard-fixings-metal-35mm-100-pack/47347
https://www.screwfix.com/p/rawlplug-hollow-wall-anchors-m5-x-37mm-20-pack/99201
Hopefully this will be useful for someone. I'm not getting commission for these links (boo). Doubtless other manufacturers and suppliers will have similar offerings.
I think the self drive plasterboard fixings are made from an alloy so they may well melt too early as well. Though I do not know the alloy used.
The metal wall plugs are probably the simplest but would have really too great a sideways force for weak substrates and could readily shatter the wall.
Presumably someone will come up with a product like the D line clips, vastly overpriced and annoying.
Interesting. Perhaps we need some clarification about which metals are suitable and how we identify them.
It's also occurred to me that perhaps fixing cables to plasterboard is not acceptable from a fire resistance point of view. The regs already say a light must be fixed to the joists or similar to avoid the plasterboard giving way in the event of a fire burning off the paper - perhaps the same should go for cables, but I don't remember seeing this on my initial look at the changed regs. Roll on amendment 1 :-D
Do any of you old geezers out there remember ALEX plugs in the 70's. They were an aluminium rawlplug an always gave you a solid fixing - much better than the plastic ones. Perhaps they are the solution to this problem.
Yes I most certainly do and stupidly made a mistake when I ordered the last batch. I wrote 1000 on the order against each of 4 sizes along with various sizes of screws and no one questioned the quantity. The delivery was made, the invoice sent and account paid, all 3 being done in their usual efficient manner. Imagine my surprise when I next went to the shelf and found 28 boxes containing 144 boxes each of 200 alex plugs on the floor where I expected to see 20 small boxes on the shelf. Weirdly there were only 5 boxes of each size of screw delivered.
Now the question of closing down the branch cropped up a short while later and by the stroke of a pen, guys with clipboards decided there was no stock worth the cost of moving to another branch and I got the job to arrange skips and disposal. 41 years later I probably still have 25% of them as I'm slowing down towards retirement.
Do they? Which regulation is that?
Just checked and they don't :oops:. What they do say (to paraphrase and abbreviate) is that adequate means to fix shall be provided, capable of supporting not less that 5kg, and installed in accordance with manufacturer's instructions. I'd question the ability of plasterboard to support 5kG with any form of raw plug (perhaps others can correct me), and I know at least some manufacturers' instructions specify fixing to joists or other timber rather than plasterboard. Where I have read that this is to avoid the plasterboard giving way in the event of a fire burning off the paper, I couldn't tell you.
Other than ceiling roses, I would suggest most domestic surface mounted luminaries subsequently installed, would have to make use of said plasterboard fixings. If you were installing something heavy, aka an old fashioned chandelier, these types of fixings (in a horizonal plane) would not be suitable, and an alternate fixing method would have to be employed.
Plasterboard primary role, is to provided fire protection for load bearing structures. Cutting holes in said plasterboard, may cause that fire protection to fail, if not suitable sealed.
Spoon
Mentor
Lancashire
United Kingdom
Electrical Engineer (Qualified)
The use of plastic wall plugs for the 18th....
Spoon,
Pete999,
