Think I'm losing my touch. | Page 2 | on ElectriciansForums
Discuss Think I'm losing my touch. in the Talk Electrician area at ElectriciansForums.net
Just a point guys , its so difficult to locate every item plugged in especially on lighting circuits , there is always something plugged in some where you've not spotted , what i do is carry out the IR tests LN initially at 250 volts then if clear repeat the test at 500 volts doing this reduces the risk of equipment damage if there is some thing still plugged in
And that's exactly what I do as well. It's a top tip and it could save you the price of a widescreen.
Reply to Think I'm losing my touch. in the Talk Electrician area at ElectriciansForums.net
Very technical :D
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
