After quite few threads ive seen here on whether care-homes is Commercial or Domestic and notifiable or not, i spoke with Elecsa
and they advised that work im doing in a care-home WOULD BE notifiable....Reason being that the requirements of Part P states
on page 5, The example of Appication: A dwelling and business that have common supply....The reasoning being the people/residents are dwelling
although it is a business....Works that come under the Part P requirements, on any of the circuits effecting the ones dwelling there from
the common supply should be notified as normal...
Thought was quite interesting and logical response from them.....
have question though
Im replacing a fuse board at this site......going for RCBO's as they cant have multiple circuits going down if fault, but was wondering.
Would i be required to give RCD/RCBO protection to circuits only used by staff, or even the lighting in certain areas...as at present there is no RCD protection at all just very Old Mcb's . (With Damaged board hence replacement).
BTW. Been awhile since logged on so my apologises for not sharing and being involved for A while.
