C
craig1000
Static Caravan Park - been asked to look at continuing some work that's was started by a bloke (who was not spark) who has since died :-(......
4c x 25mm from 3p phase DB at incomer position goes off too a number of external enclosures looping from one to the next.
At each point there are henleys blocks fitted and then a 6mm (single phase) taken through a RCD and off into a caravan.
At the final point there is a 6mm and it goes off to loop feed x 5 caravans.
Total of 12 caravans fed I believe.
At the DB the cable is fed via 3 x SINGLE PHASE mcbs so the caravan park owner can shut 'sections' off at time for maintenance rather than the whole side of the park.
I haven't gone to see this yet myself - just gathered what info I can and had one of my lads call in briefly to have a look.
