Sorry morp but I must be reading a different post.
First EICR
6mm twin and earth cable for shower connected in a 45amp bs1361 = code 2
Shower not rcd protected = code 3
(Shower no RCD protected by 45 A 1361)
external influences so yes ok for pendant
but code 2 for suppleymentary no , why ? because it is not potentially dangerous irespective of the rcd requirement
so code 3 IMO
Your interpretation of the regs is totally different to mine if you are of the opinion that this is a code 3 and will attain a satisfactory assessment on your report!
its only the supplementary bit i disagreed with , under the 16th it would not have needed rcd for all circuits , so it only lacks the supplymentary bonding , which i would code 3
under 17th it would require rcd and supplymentary , using ESC guidlines it would be code 2 ,
its easy to forget the content of threads that span time which i have appeared to have done , however i could argue either way as to whether its potentialy dangerous, after all any installation is potentialy dangerous when something goes wrong or has human intervention
I will have to agree to disagree Morph.
Supplementary bonding under EEBADS was still required to locations of increased shock risk and failure to istall in my book was and is still a Code 2.
I will stick to GN 8 information re this !
Regards
Tony
thoughts please
Talk Electrician Forum
mcm,
tony mc,
