Three lights one switch | on ElectriciansForums
Discuss Three lights one switch in the UK Electrical Forum area at ElectriciansForums.net
Jonny, if you are not sure of how to do this simple job, then I would suggest your best option would be to employ the services of an Electrician, you could meddle with this unill eventually you may get it right, but it could prove expensive and more importantly dangerous, call an Electrician, get it done right first time, save time and money in the end.
Always made off with H/R flex into back box behind fitting with low energy/LED lamp.
I agree with your method but I was getting at the DIYer trying to connect the multitude of fittings which can be obtained from these places in a safe manner.
Reply to Three lights one switch in the UK Electrical Forum area at ElectriciansForums.net
It's unlikely tht a small domestic garden pump and a single lamp will come anywhere near close to overloading even the smallest (3A) fused spur...
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
