Three lights one switch | Page 2 | on ElectriciansForums
Discuss Three lights one switch in the UK Electrical Forum area at ElectriciansForums.net
I'd avoid the like of B&Q and Wickes for light fittings, they may seem good value but they are poor quality when compared to what you'll get for the same sort of money at a proper electrical shop. We got 9 spots at edmondsons for a couple of ÂŁ each the other day because they were selling them off, couldn't go wrong.
That's OK if all you're after is cast off spots, can't see the likes of CEF pandering to Mrs Pete999s taste in light fittings though.
don't think CEF ever did gas lamps anyway. :p
Not just limited to the connections, although they can often be fiddly. Fitted spots from there not long ago, not cheap but poor fitting (springs not stiff enough to hold in place). I just find it easier to get fittings from a specialist lighting or electrical place to try and avoid problems.
Think we need to try and understand, the OP is a DIY chap asking for help, we can all get specialised stuff from our local wholesaler, this Chap probably can't the best option he has imo is to get in touch with a local Electrician, who will be able to help, some people who buy from the Orange shed often get away with things, in this case, the OP is stumped, OP get a sparky in to put your light up no more than an hours work and it will give you peace of mind that it has been done safely.
Pete the OP is talking about 3 new lights and all the wiring too as I understand it , so I'd say more a day than an hour. :)
I have just bought these lights from B & Q
Volos Sphere White Single Wall Light | Departments | DIY at B&Q - http://www.diy.com/departments/volos-sphere-white-single-wall-light/258109_BQ.prd
I'm wanting to wire them (3) to one switch.
What's the safest and easiest way to do this please?
Many thanks in advance!!!!
If you do not know the meaning of " Loop in loop out", put your hand in your pocket and employ an electrician. No electrician would get his supplies from B & Q.
What about on a Sunday when all the Wholesalers are closed, and you want something quick, and you're 5 mins away from B and Q and 20 mins from Screw fix, and your dinner is 30 mins from being cooked and you don't want to miss it cus it's Pork , so do you try the orange shed or waste time going to Screw-fix? the choice is yours mate, I know which way I would lean.
Yes you'd lean towards the dinner plate Pete, finish the job first thing Monday. :D
Don't think so Dave quick trip to the shed get what you need jobs a good one, home for me din dins start afresh Monday, don't go to B and Q my foot, if they have it in stock buy it do the job end of.
Reply to Three lights one switch in the UK Electrical Forum area at ElectriciansForums.net
It's unlikely tht a small domestic garden pump and a single lamp will come anywhere near close to overloading even the smallest (3A) fused spur...
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
