Three phase DB, water, you can geuss! | on ElectriciansForums
Discuss Three phase DB, water, you can geuss! in the Commercial Electrical Advice area at ElectriciansForums.net
J
J25GTi
Well, having just joined up i thought id post some of the work i get involved with and what not and generally introduce myself!
Im Jamie, I'm 22, and an industrial/commercial electrician in the southwest.
Generally i get alot of fault finding and reactive installation work to do, and I'm just in the process of going self employed now.
But anyway, i went to a site the other day to carry out a EICR and this is what was awaiting me! A 50a TP-N DB that was mounted next to a garage door and was been leaked on by the roof!
[ElectriciansForums.net] Three phase DB, water, you can geuss!
As you can see its a bit of a mess!
Well, it turns out that <3 months ago a large electrical contractor in the area had fitted a new supply to the forklift charger (50a single phase), but didnt have any cable big enough so they doubled up 2x 6mm cables for L,N,E, *rolls eyes*
It also turns out the MCB was upside down, causing mass confusion to the guys on site as it kept tripping out due to only been a "b" type
Earth didnt quite fit in the terminal it seems -
So I isolated the board and made safe and the client agreed to let us install a new fuseboard and sort out the cabling issues!
Found a burnt out lighting circuit then realised this might have something to do with it -
So on with a new DB and enclosure,
I elected for a GRP IP65 enclosure with an eaton TP-N DB inside with all cables + conduits passed through the GRP enclosure with stuffing glands and suitable washers with weather proof glands going into the DB.
New supply for the forklift charger -
Lighting Circuit renewed -
There we have it,
Hopefully they are all up to your exacting standards, and C+C is welcome!
Jamie
well i aint in the industrial sector (as yet)...but your heart sinks when you see stuff like the earthing and back to front MCBs....protius n all wherever you find it.....
Welcome to the forum....
By the way, there's nothing wrong with parallel supplies, so no need to roll your eyes to far...lol!!!
For a 50A supply requirement they could of used 2 X 4mm, easier to pull and all!! lol!!
Now explain to me why there is nothing wrong with it? I dont quite see it?
If you have 2x cables capable of 30a each, running a 50 a load, and one leg fails, you end up with one cable running 50a thats only rated to 30a?
Reply to Three phase DB, water, you can geuss! in the Commercial Electrical Advice area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
You'd have to be mindful of SPD conductor lengths doing it that way. I think Matt:E make a single board with Type A RCBO, openPEN detection and...
