K
Knobhead
We’re talking of power feeds to a MCC so possibly a 1200A feed. I don’t think it would fit in a CU.
Read through a post before commenting.
Lets hope they have sorted the leak in the roof!!
What I would say is, it looks if the MCB they put in is the right way round, the MCB spring clip is supposed to be on the outside, well hager boards always state it.
Correction, that's what you were talking about. The OP and indeed all the first page mention noting above 50A and 4mm. The attached pictures are of MCBs that 185mm wouldn't fit in to them would they?
I was merely making the point (someone else already made it earlier in the thread!!) about the principal of a ring so it relates to other areas as many people don't know about cables in parallel.
As he always instilled the view on us that rings were inherently dangerous if you lost a leg etc then you have 2x 25a cables running on a 32a mcb etc. So this would be where i have formed this opinion from.
Reply to the thread, titled "Three phase DB, water, you can geuss!" which is posted in Commercial Electrical Advice on Electricians Forums.
