Three phase INDUSTRIAL fuse board recommendation | Page 2 | on ElectriciansForums
Discuss Three phase INDUSTRIAL fuse board recommendation in the Commercial Electrical Advice area at ElectriciansForums.net
Schneider is good, crabtree also good and I have used a few contactum boards at lower end of budget which have also been surprisingly good. Not a fan of hager have a cheap feel to the dist board and definetly not good value for money I'd avoid
I was looking at one of the new Schneider boards in the wholesalers today..
The RCBO seemed a bit loose in its terminals..
Is this usual with the new push in type or is there a secure locking mechanism rather than just the push in din rail clip?
Still making good contact I suppose, just like other push in terminals..
Got a 36 way board swap next week so I’m going to get one and see how it goes..
The Hager boards also waste so much room, for equal size boards the Schneider has many more ways
SJD can you fit 2 boards in Coventry? I have list of circuits
I need 2.new board Schneider or Hager. I prefer a complete solution with fitted energy meters and RCBOs. Each board will be fitted with 63A 3 phase breaker.
There is one incoming supply.100A we will split it in two circuits to feed 2 building
Reply to Three phase INDUSTRIAL fuse board recommendation in the Commercial Electrical Advice area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
Sooo the client has accepted that we don't want to be fraudulently taking electricity so that worry is out of the picture. But now basically the...
5K
