Davido
Hi Folks,
I have a question about a property in Spain and its power supply
I think I have messed up with my electrical company and asked them to supply me with a lower potential than I require. The house did have a 12,000 KW supply, I asked for a night rate and in order to get this I had to opt for a different power connection either 10,000W or 6500W. I assumed that the 6500W would be per phase I am thinking now it is 6500W in total.
The day they changed the meter the oven started tripping the RCD, the hob also trips it.
Is it usual for an RCD to trip but not latch down just to trip the power? It can be reset by toggling the switch.
Would not having enough power in the one of the phases cause the RCD to trip?
The bumer is if I have to ask to get the higher 10,000W rate I will have to have the house certified again. Is there any way that all three phases can be used together to give me more power?
Thanks in advance
Thanks in advance
