P
peteandrewd
Hey everyone. Bit of a silly noob question.
On my dirt bike, as I was tightening the positive battery terminal lead(it was loose), the allen key slipped and hit against the subframe causing a short and sparks everywhere, and causing the allen key to be extremely hot to touch.
It was only for a millisecond or 2, but I'm wondering if I would've done any damage to the electrical components of the bike(such as the alternator, rectifier/regulator, etc), or to the battery itself?
None of the fuses blew at all.
I was thinking that the short that happened, would be similar to having a non connected battery and simply shorting out between the positive and negative terminals, therefore it wouldn't of gone along the path where the fuses or any other electrical components run from, is that correct?
