P
peteandrewd
Well it's a dirt bike, so it doesn't have many sensors. The only sensor in it is a pulse generator which is inside the flywheel cover for the ignition, and it's a carburettor powered dirt bike so the only sensor on that is the throttle position sensor.
The only other components are the digital ignition box(provides spark and what the TPS is connected to), and ignition coil, and obviously starter motor that is connected into a solenoid with 2 fuses(that the positive battery cable also connects into). It's all connected into the 1 main wiring loom but protected by those two 10 amp fuses.
The only things that run when the bike is off is obviously the electric starter and horn and indicators. It doesn't have an ECU as such.
