Discuss Time delay relay in the UK Electrical Forum area at ElectriciansForums.net
Just wondering how that keypad would work on a shutter door, where you would normally hold the button or sprung key lock over to go up or down.Most lock keypads have lock timing built in.
I normally use the ACT5e keypads and haven't had an issue with them yet.
If you want it to be secure, then a wireless keypad would be better.I want to put a code pad via a time delay relay on a shutter door, any recommendations?
Do a search for wireless keypad door openers.
Because the keypad isn't hard-wired to the door opening mechanism, so you wouldn't be able to simply bypass the keypad.How is wireless more secure?
Reply to Time delay relay in the UK Electrical Forum area at ElectriciansForums.net
