Time delay switch for a 2/3kw heater? | Page 2 | on ElectriciansForums
Discuss Time delay switch for a 2/3kw heater? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yeah, never done heaters before so it's all a bit new to me to be honest so just wanted a second opinion. Cheers for the help buddy.
Reply to Time delay switch for a 2/3kw heater? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
I doubt the terminals in those are suitable for 4mm, more likely designed for 1.5mm as they are limited to 16A. You could use the time switch to...
davesparks
