W
wadhamfarm
Hi Guys,
A Metalcad CU is being installed on a TT system in a farm garage. Chances arew things will be rested up against the walls so a Metalclad CU has been chosen to give it protection.
All circuits will be protected by 30mA RCD / RCBO.
From research it seems a 100mA time delayed RCD will be needed to protect the tails entering the metalclad CU.
My next thought was that the time delayed RCD will need a Metalclad enclosure to give it the mechanical protection.
Surely then the tails entering the enclosure will also need RCD protection?
Whats the best way to get the mechanical protection needed for this system?
Thanks in advance!
Thanks in advance!
