timeclock for a shower? | on ElectriciansForums
Discuss timeclock for a shower? in the Australia area at ElectriciansForums.net
K
Kev2632
Is it possible to get the shower on a timeclock for certains lengths of times,
Its for the children because they always have really long showers, haha, so trying to cut it down with a timeclock,
would it go through a 40amp contactor, and then use the timeclock/timeswitch to switch the coil??
what kind of timeclock, would you recommend ?
Its not the best idea to switch a domestic shower using its supply or it may burn out the shower damaging its components, most now have a slow shut down when you press off which stops it being full of hot water when turned off.
a coin meter/timer could be used but is only recommended on a commercial design product.
Just been looking its a 16A unit for lights to make sure they are not on to long - dont know if you could incorporated a relay into it
Search for: [h=1]Outdoor 3 Wire Touch Activated Timer[/h]
in B&Q - ÂŁ45
yea but doesnt work, im afraid, so im just scheming something like this, would that kind off switch be ok for that setup, as its only switching the coil of the contactor and not the full load???
Reply to timeclock for a shower? in the Australia area at ElectriciansForums.net
