Timer and contractor | Page 2 | on ElectriciansForums
Discuss Timer and contractor in the UK Electrical Forum area at ElectriciansForums.net
E
egginyourface
Can I have feed from load side of a timer powering a contractor which when energised allows a different feed from a different distribution board to liven up a load.
What I have there is a normal light point with s/l and permanent feed. Customer wants it to work off timer. Only thing is no neutral. So I'm planning on taking permanent feed from a spur to contractor to timer then iin with my permanent frm lighting circuit and energise switched live, does this make sense
Its all supplied from the same phase. Its just that one board is rcd protected. Also board is well out of reach. Will try to take a picture tomorrow and post it.
Ive told the customer it needs to be moved as it would be impossible to locate a fault if i needed access to the internals of the board.
Reply to Timer and contractor in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Thanks I understand it now just getting to grips now with the different types and different ways of wiring them
