They will have sent it to you when you applied or else it is on their website.
It tells you exactly what you need to have and what to expect.
I got an email with a list of paperwork I needed to sort out and that’s about it
Firstly I didn’t say safe isolation would ever be obsolete, I said ensuring it’s 100% guaranteed safe (which isn’t achievable as someone previously stated) becomes obsolete.What times are those? If you are working live then you will be following a very detailed plan of the work written specifically for the task and will be using temporary insulation, fully insulated tools etc and wearing suitable fire resistant clothing, arc shields etc. None of this makes safe isolation a 'little bit obsolete'
Anyway, I thought you said earlier you only do domestic? There's never a need to work live in domestic work!
Working live is only really going to be considered when paying out the compensation for killing someone is cheaper than the loss of profit from shutting down production.
If your working on an apartment in an occupied block of flats, are you going to shut the entire building down purely to work on that one flat? I’ve been in this situation and even after knocking on each apartment to ask if shutting down the power is ok, there is still atleast 1 or 2 that you can’t get into. I always use fully insulated tools and would use temporary insulation but I can honestly say I have never found the need to wear fire proof clothing and use arc shields when working in a domestic or commercial environment.
I was talking about the sub main feeding all the said apartments. On paper it’s fine stating exactly how things should be done but in reality it doesn’t always work that way. Sometimes the job has to be done and it can’t always be done 100% to the book. I think anyone who says they’ve always 100% done things to the book is a liar, in my opinion.No, but I woukd arrange to isolate the feed to that particular flat if necessary. There will be a means of isolation for the supply to each flat. If work is required to the live side of that means of isolation then you have to contact the BNO to arrange the necessary permissions etc.
I would give it a second check with an alternative test instrument. Even if it’s a volt pen.
They turned off the power to my local neighbourhood recently, to do some supply work. Sent round a nice little letter a few weeks before. Can't see its a problem. As davesparks said, you should have very good reasons to work live, otherwise you's be in trouble with HSE, should it all go wrong & you survive.
I've had my hands inside a live DB to do some very minor stuff before now, but no one would come to my aid (not literary) if it went wrong.
I would only rely on these as a secondary or even third option. Just to check that my primary testing equiptment was correct. It’s purely a back up option in the case stated by someone previouslyI wouldn't rely on one of those, with my health on the line. The only way to know that something is 'off', is when it was 'on' and then you've just turned it 'off'.![]()
You’ve had your hands inside a live dB board so therefore you cannot say you’ve always followed the book 100%.
Totally agree with you and it’s most certainly not something I would make a habit of doingIts that mindset though; I've done it once or twice, it'll be alright.![]()
I was encouraged to go down the AC route with NICEIC and was told by the assessor if the focus is on domestic in your business, then you can show just domestic jobs. As always I gather that Certsure can be flexible when a cheque is involved.You can use your own premises as on eof the sample jobs.
If it is a domestic installer registration then one domestic job is required.
If it is an approved contractor registration then it needs to be 3 sample jobs demonstrating the full spectrum of work you carry out, not just domestic work.
Get a proving unit and voltage tester, plenty of good offers out there at the moment.Are the nic going to want to see an approved voltage tester and proving unit? Or can I get away with using my fluke t5-1000 and proving it on a known source when doing safe isolation, which I’m assuming you’ll have to show?
Does my fluke t5-1000 count as a voltage indicator? I’m aware it indicates when there is a voltage present but it’s not dedicated to just this function. My megger multimeter can also indicate when a voltage is present but i know that niceic don’t recognise this as a reliable source for whatever reasonGet a proving unit and voltage tester, plenty of good offers out there at the moment.
Have a look at this mate , it was part of the old 2391 exam too.Does my fluke t5-1000 count as a voltage indicator? I’m aware it indicates when there is a voltage present but it’s not dedicated to just this function. My megger multimeter can also indicate when a voltage is present but i know that niceic don’t recognise this as a reliable source for whatever reason
Money spent on safety equipment is never wasted. It could save your or someone's life.Thanks. I’ll get myself a new voltage detector and proving unit then. What with all the new 18th edition books I’ve bought, the 18th edition course I’ve booked and the niceic subscription and initial assessment costs, this is proving to be a rather costly experience. I hope it’s worth it
That's the one I have . I also have a 30+ year old - non singing non dancing Stienel voltage tester.Something else I bought off the megger man last week
That now takes my total to about 8 different types..
He’ll be looking for a GS38 compliant voltage tester. You can get GS38 probes for the fluke. TS38.Are the nic going to want to see an approved voltage tester and proving unit? Or can I get away with using my fluke t5-1000 and proving it on a known source when doing safe isolation, which I’m assuming you’ll have to show?
As for dealing with the dno. This is absolutely fine if you have an unlimited budget and 6 months to complete every job.
Has anyone got any recommendations on a decent yet not too expensive proving unit and voltage indicator?
