NICEIC Certification Scheme Tips for my first niceic inspection
You’ll be fine with all domestic. An EICR is good but really ensure your report is accurate as my inspector even had me working out csa and copper equivalent of a 6mm steel bolt. No need for commercial as some ACs never do anything but domestic. The engineers are pretty good guys and don’t mind if you have a few gaps in knowledge, as long as you’re safe and working to a good standard, and you know where to find what you don’t know you will be golden. Always get them talking about their work history as it fills the awkward spaces between jobs etc. Good luck
Thanks for the advice mate I’ll bare it all in mind
Make sure your wifey or girl or boyfriend is ready first in bed.
And leave a apple on the table just in case to ram it down is throat in case you dont pass.lol.
Are the nic going to want to see an approved voltage tester and proving unit? Or can I get away with using my fluke t5-1000 and proving it on a known source when doing safe isolation, which I’m assuming you’ll have to show?
When I did my Elecsa assessments (domestic), I used a known source to do safe isolation. However, I did have a proving unit also. If you’re doing commercial/industrial, or new builds, there might be an occasion when you won’t have that known source, so why not get yourself a proving unit. You are responsible for your safety.:-)
I have never used a proving unit.
Hang on, I think I did when I done my testing and inspection assessment..
The trouble I have with proving units is that I don’t trust them.
What do you do when a live supply isn't readily available or safely accessible?
That's why you prove the avi before and after testing, it shows that both the avi and proving unit are working.
Have you read through the niceic's guidance for new applicants? Questions like this are answered there.
For the cost of a cheap proving unit I would just buy one and sling it in your tool box for assessment day...
What I have done for the last 27 years is test the supply before isolating and then test it again after isolating it.. Then test the primary side again..
I have never been in a situation where I need a proving unit. I personally wouldn’t put my life or any one else’s in the hands of a proving unit..
There must be occasions however, when you test your supply before isolating and a tester indicates the supply is dead. How do you prove the voltage tester is not faulty, without access to a know live supply?
To be honest I’ve always tested on a known live supply. I can’t think of any situation I’ve been in where there’s not a known live supply somewhere in the near vicinity. Personally I have more than one voltage indicator/testing device on me at any one time so if there’s any doubt i can always test with another to verify
In my opinion this scenario could continue forever. 15 testers/proving units/voltage indicators down the line there is still no way of truely proving that all the instruments are in perfect working order
