Tips | on ElectriciansForums
Discuss Tips in the Australia area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
Just a thought. How about a thread covering hints and tips, nothing too technical, just if any members have useful tips or know of gadgets that save time and money ( without cutting corners, of course ) let's have 'em
a good set of rods for saving time (or trunking lid)
a fein or equivalent multi tool
good strong magnet and compass for lining up through walls etc
best tip i could give is make sure if poss you get the right stuff the first time round as there is no fun in buying twice
for ladder work i use a 2ft length od galv. conduit inside a rung just at waist level with a bucket hung on it. drill, hammerand allsorts can go in it and be easily picked out. also any rubbish from fittings removed can go in , saves having to go all round bending down
Keep stocked up, nothing worse than having to break off a job to do an hour round trip to merchants for a single pattress, or turning up to a light fault and you need a pendant, but you used the last one yesterday.
Reply to Tips in the Australia area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
