stuban
Hi,
[introduction in new members section]
We have a CU to fit to replace a re-wireable fuse board. The incomers are pretty new and look to have been fitted fairly recently. However it looks like a tn-c-s with one major missing factor... No earth block from the incoming Neutral. There's no earth stake so it's not a TT. There seem to be CPC's connected to the terminal in the fuse board but there's not actual earth to the block.
In your experience what's the best way to proceed? We've contacted the board and booked in a visit(next week!) for them to check it out and tell us if it's set up for tn-c-s or whether we need to put a stake in for TT.
In you chaps experience is there any way that we could confirm(either way) this by testing or is this the only way to go?
Could we equally just use it as a TT(assuming the Ze was OK)?
Thanks in advance
Stu
Thanks in advance
Stu
