Guest viewing is limited
Well that's not completely true at all. So what do you think happens when a TN-S supply is converted to TNC-S/PME??
They will only use crimped connections when a joint is replaced, they certainly aren't going to replace every joint on the distribution supply run before converting a households service head. It maybe several years before a converted distribution cable is fully PME'd, and is more likely than not, supplying both TN-S and TNC-S during that period.
By the way, there is nothing wrong at all, with soldered joint connections, they have been around long, long before crimped connections, they are as sound as any crimp connection too. There are very few circumstances where soldered terminations are not advised or permitted...
Ok, I must have misunderstood, i thought we were talking about overhead supplies here. The OP was talking about OH and so i have continued in that same area. I have never seen an underground supply that is TT unless the incoming earth has been lost at the joint underground. I would not expect a DNO to replace its cables underground just to implement PME, and i have not experienced a TNS service converted into PME without the service being replaced. In my areas if a TNS service is moved within a property they leave it as TNS and do not convert it to PME
I was not talking down soldered joints or connections, and yes i agreee there are many that are still in service and will be for years. However most DNO have moved over to crimp or more accurately shear off connections because of time and cost factors, but also they have a lower failiure rate than soldered joints. Now before everyone gets on thier soap box, i am not saying this is my point of view but that of the DNO i worked for and the jointers and linesmen who were using them on the cables that i spoke to and asked about it.
It was also the policy of SSE at one point that they would replace the old bare conductors with an insulated bundled service wherever possible, and then use concentric down to the head. If the main OH service was not easy to replace they would still replace the bare conductors into the property with concentric and when it was connected to the existing OH main Shearoff would be used. That would replace all connections along the length of the main; once all services had been connected, it would be staked down and labeled as PME.
They must be fairly common, we have an underground supply and we're on a TT.
Thats just a great example of the vastness of detail and differences across areas. There are many combinations and permutations.
It's a big subject and to have seen it all & know it all would be some going.
TN-C-S or TT?
Thread Tags
phawk,
Guitarist,
