TN-S or TN-C-S? | Page 2 | on ElectriciansForums
Discuss TN-S or TN-C-S? in the Australia area at ElectriciansForums.net
M
manda
Whilst having a quick nosy at my mum's supply I came across a recent installation certificate that was left when her new central heating system was fitted. Before reading the certificate, I was of the opinion it was a TN-C-S supply. However, according to the certificate, they noted it as a TN-S supply with A Ze of 0.22. So I thought I'd stick a few photo's up and see what you guys think as I'm now a tad confused :confused:
  • [ElectriciansForums.net] TN-S or TN-C-S?
There's no RCD in the CU, so the upfront RCD was probably just installed to provide RCD protection rather than anything to do with Zs
Well I'll have to take your word for that as you most likely have younger eyes than me, and that is why I said seem to have as I wasnt sure ...................thank you
I recognise the wylex CU and the main switch ;) The 2 way CU does have an RCD though.
As it is a submain, you can't determine the type of supply without checking the origin.
As we say its MICC and your getting the earth via the sheath and then onto your BMT via that small earth. You are going to have to find out at the origin of the supply, ie where the DNO main head is to get your Ze, what you will most likely find is that the Ze on your schedule of results are a Zdb from your mums board, if it was then it should be mentioned as such on the EIC, as I would guess they would not have arranged to disconnect the earth conductor at origin, as it would mean isolating other flats and communal area.
There is no earth to the metalic cable, at least not on the outside of the cut out. It is sealed and I don't fancy breaking the seal just to nosy. As for testing it, there is soon to be some work done, so I'll get it tested then out of interest. I don't know if it was previously a TT system, she's only been in there 5 years so all I can say is not in that time. Just wondered if I was missing something that was visually obvious without breaking the seal. Also, would a Ze of 0.22 be acceptable for TN-S as I thought the Maximum was 0.8 thus making it more likely to be a TN-C_S?
the pyro copper sheath is the earth,it is bonded to the metal case by the gland, the earth is then taken from this metal case, used to be common in the old days,but the loads were nowhere near as much as they are nowadays, nor the regs as stringent
0.22 is acceptable for tn-s and tn-c-s maximums are 0.8 for tn-s and 0.35 for tn-c-s
the pyro copper sheath is the earth,it is bonded to the metal case by the gland, the earth is then taken from this metal case, used to be common in the old days,but the loads were nowhere near as much as they are nowadays,or the regs as stringent
But if this is a distribution circuit then we're all just guessing the system type!
They were originally fitted as a package,the head containing the fuse and the metal clad dist board
The bolt on the casing normally provides the connection to a Tns system,earth cable bolted to that section
Before the old metal clad was removed it would have been directly bolted to the head and the tail you see was also linking both
In another thread I stated a TT system need have no RCd before the tails where precautions have been taken against them shorting to the metal,in this case, it seems the Rcd should also protect the tails
To the question,every one of these were probably original Tns and with there being no change of the head I would say its Tns
I managed a few beers to calm my shattered nerves earlier, after watching my mum try out her new disability scooter. She will be getting insurance for it, including 2 million squids of public liability, me thinks she may need it! ;)
Reply to TN-S or TN-C-S? in the Australia area at ElectriciansForums.net
A bit like saying plumbers makes good electricians. 🥴
How did it go?
