TN-S or TN-C-S | Page 2 | on ElectriciansForums
Discuss TN-S or TN-C-S in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
mmmmm so you look at your main incoming cable/cables in your main switch and the neutral is bolted/connected directly onto earth as has been stated is sometimes done............how would you say that is TN-S?
A N-E link at the main switchboard won't be at the main switch, but between the earth and neutral switchboard bus bars. The link will also normally be a removable bus bar link.... It won't necessarily be in the same compartment as the main incoming switch either, but in a cabling compartment!!
see engineer54's comments above, I would agree, we see it often always TNS on reports and backed by NICEIC on annual inspection last year
Ahhhh right..........was having trouble visualizing that.
Good explanation thanks.
[ElectriciansForums.net] TN-S or TN-C-S
Reply to TN-S or TN-C-S in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
Indeed, that was my thought, a B20 having a 60A instantanious trip should easily cover a inrush for a domestic fridge, and if the fridge and...
