M
Mewff91
Hi all
Went to look at a consumer unit change today.
Supply is tncs
all bonding is correct.
I noticed that where the supply is there is no main earthing terminal.
The consumer unit has been used for all bonding and circuit cpcs.
Just wondered weather i should install new met at point of supply and run the cables here or leave at the consumer unit. It will be a bit tricky to do this though.
Just wanted to hear your opinions.
Cheers
Supply is tncs
Cheers
