Tncs or TT ? | Page 2 | on ElectriciansForums
Discuss Tncs or TT ? in the UK Electrical Forum area at ElectriciansForums.net
bristol
Does the DNO change TT systems into tncs by changing the head to a tncs cut out and providing met? The Ze I measured was 0.60 and when main earth reconnected reding of 0.40 on the met . There is an earth electrode and 30 mA rcd as a main switch . Is this a TT system or tncs ?
Job today had TT in place and connected through to CU. Service head/cut out has PME sticker but no earthing conductor through to CU. Householder advises that they had a meter change approx five tears ago. Since that time they've had PV fitted and a CU change. No cert for CU change but householder advises it was the same guy who did the PV hook up. There is a cert for that, recorded as tncs... Fun city.
Haha.although the few PV installs ive seen I havent thought much to the hook up at the board/meter.
My job today had TT. full test following DB changes. Had 5 hours of, on average, 2.8ohms Ze to the circuits. Then it jumped to readings of 28.3ohms. Any ideas other than tester batteries might be dying?
Thanks :) just glad its nothing monumental. Already knew batteries were getting lowish, enough to tell myself to remember i need new batteries so its likely that :)
Checked board connections :)
Reply to Tncs or TT ? in the UK Electrical Forum area at ElectriciansForums.net
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
