TNCS Service head, earthing and bonding | on ElectriciansForums
Discuss TNCS Service head, earthing and bonding in the UK Electrical Forum area at ElectriciansForums.net
Essex
Went to quote for customer's dis board upgrade today found this gem! looks like 6mm main earthing, main bonding etc going into the MET within service head.. also no plastic case on head. I presume I would contact DNO to resolve and provide 16mm + additional MET? Just haven't come across this yet.
There are other big issues with the installation that are obvious so quoted for EICR previous to DB change. Also don't fully understand why there are two meters still as DNO fitted digital one only a few years ago? I think the other one is redundant as can't see what its supplying... there has never had a rented area within the property to justify another meter..
thanks
[ElectriciansForums.net] TNCS Service head, earthing and bonding
I had all the Economy 7 gear still present in my own house until earlier this year, even though it hadn't been used for over a decade. Had to take two meter readings each time even though they were both charged at the same rate.
Eh...?
look at it again...
Maybe i'm getting really confused, the earth block is attached to the service head, in the picture it hasn't got a cover like it normally would have... would it be ok for me to put a 16mm earth into that block without the DNO? seeing that its their property?
Is it the same "whose responsibility is it" situation, like it is with the pulling of main fuses, for example? sorry for not being clearer in initial post, been a long day..
christ give me strength...
just upgrade the main earthing & bonding to current ed BS7671...you have access to it...dont you....
and why does the earth block on that cutout need a cover?...
is it normally considered live?
There was never a cover over the earth block on that type of cutout. It is left exposed for the electrician to connect the main earth conductor to so if you are an electrician JFDI.
Modern cut outs have either drilled holes or a removable cover for access to the earth block screws.
yep will do
not sure, all i'm saying is they normally do... or so i thought
no of course not. I think i've overthought this! thanks for your help though..
Reply to TNCS Service head, earthing and bonding in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
Recommended Sponsor News
Hi everyone,
