TNCS - USING NEUTRAL AS EARTH IN BOARD | on ElectriciansForums
Discuss TNCS - USING NEUTRAL AS EARTH IN BOARD in the UK Electrical Forum area at ElectriciansForums.net
London
Im travelling abroad to a country that has no earthing arrangement and my friend would like me to do a bit of work on his house. My question is Whether or not i could create a link between the Neutral and Earth bar to create a tncs system.
I know it sounds strange but i have just been thinking for the past couple of days how they do it here in the uk. They do the same thing for tncs systems a link between neutral and earth.
Could someone shine some light on the subject as to why it cannot be done and how it can be done here then?
P.s i know a earth rod can be hit into the ground but want to explore all options.
I know nothing of other countries,but here the star point of the supply transformer is connected to earth and spiked along its run to keep it at or close to earth potential
Probably,the star point is earthed
If the supply then comes direct without the neutral and earth being spiked,its then jointed at the load end,the property earth and the true earth may be at very different potentials
Just seen its Libya, Do they still have properties standing in that sorry land ?
Thanks for answering the queston, many still happilly standing
I would be very cautious about creating your own TN-C-S system because as Des says over here it has to confirm with specific requirements to keep the PEN at a reasonable resistance to true earth. Not knowing the setup in Libya you would be taking a huge risk doing this particularly with the hazards known with regards to a lost neutral which happens here and who knows the system reliability there.
You see this is where i cant get me head round it. Because in the uk they have tncs which is just a link , why can it not be done in every uk home. It also has the same risks as anywhere in the world for example loss of neutral.
Why for example is it different i a home where its tns . Theoretically couldnt i just not use the swa sheath as earth and just use a linkbetween live and neutral. I hope you can make some sense of what im saying
Reply to TNCS - USING NEUTRAL AS EARTH IN BOARD in the UK Electrical Forum area at ElectriciansForums.net
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
I don't think it will work with only one stake unless some meters have different operating parameters. It doesn't necessarily have to be a stake...
