Tncs? | Page 2 | on ElectriciansForums
Discuss Tncs? in the Australia area at ElectriciansForums.net
Is this supply tncs?
sleeve and connect do not replace ,with the cable comming off the sleeve of the incomming supply i very much doubt its a tncs , as all they would do it put a link to neutral on the block on the side of the cutout or external eartyhing block , it doesnt look like it does that ,it may go behind the cut out cover ,but further investigation should confirm that
replace the crap terminal block with a met terminal, upgrade your side, sleeve there side and report to dno for replacement - its there earth not yours, let them do it.
also looks tns to me
ring dno and ask
take a ze
take pfc readings if pme then pefc and pscc should be about the same
Reply to Tncs? in the Australia area at ElectriciansForums.net
and you Dave
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
