To Crimp or not to Crimp??? | Page 2 | on ElectriciansForums
Discuss To Crimp or not to Crimp??? in the Electrical Tools and Products area at ElectriciansForums.net
or maybe lift the new CU a few inches up.
Oh I see! Got pretty close then.
Had a quick look under floorboards. There's a small amount of slack there and might get a bit more if i look a few more joists away as well. Still really useful to get all these opinions for when/if it's not an option. Thanks all. I'll look in to the uninsulated ferrules as well.
Hi.
I'm just starting out on my own and really appreciate the advice given here.
I'm installing my C/U (eventually to be used for my NICEIC assessment) and I need to extend all cables 30cms max. I've done lots or research and decided to crimp them and locate within an adaptable box.
I don't want to get the wrong type of ratchet tool and butt crimps. Are the following acceptable for 1.5mm2 upto 6mm2 (different coloured sleeves aside)?
http://www.screwfix.com/p/ratchet-crimping-tool-1-0-10mm/96561
http://www.screwfix.com/p/insulated-crimp-ebb-blue-butt-pack-of-100/47402
Also, is this the best approach? Reluctant to use din rails because of cost but will if it's the best way.
Many thanks, Rob.
That doesn't look like the right tool for insulated crimps, especially considering it has positions for and is marked up for cable sizes up to 10mm whereas a crimper for insulated crimps would normally just have the three positions for the three sizes of crimp.
Reply to To Crimp or not to Crimp??? in the Electrical Tools and Products area at ElectriciansForums.net
