To RCD or not RCD an Economy 7 Board | Page 2 | on ElectriciansForums
Discuss To RCD or not RCD an Economy 7 Board in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
had same problem with e7 heaters, fitted contactors to start 5min after e7 time no more problems. I thought at the time it must be e7 contactors
Is it not the case that the contact within the storage heater is usually not very good quality and
causes a spark as it makes or breaks, this might be able to trip out an rcd, using a time delay rcd
100ms would sort the problem. I have had a similar problem with a neighbors electric strimmer.
Reply to To RCD or not RCD an Economy 7 Board in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
