I just found a patch of water below the toilet cistern. I haven't done anything yet but it appears to be the inlet pipe joint that's the problem. I was thinking take the toilet lid off and tighten the fittings, maybe get new washers if needed. I thought I'd check on here before I do anything to be on the safe side. Thanks.
Continue reading...
Continue reading...
