Toilet waste small drip leak - plumbers mait not working Amateur here. My toilet waste has a small drip leak at the join, & I was advised to use Plumbers Mait to seal it up. I did, & it worked for a while, but what I find is the putty is continuing to get wet from the leak & the seal is being broken a few days after I press it in again. Is there some kind of sleeve I could put around this to try to fix this more permanently? Advice appreciated.
Toilet waste small drip leak - plumbers mait not working to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
