1stfix2ndfix
Whos a silly boy.
now i can continue
now i can continue
the first one for 2.85
R= 1
1/10 + 1/20 + 1/5
=0.35 ?
what am i doing wrong lol
I've just been looking at series and parellel 1stfix, although on a 12V scale. I haven't come across a situation yet in the domestic setting though.
My way of understanding it on a basic level which is all I can take at the moment is :
They are all 1.5V batteries but depending if they are linked in parallel or series the voltage either increases or stays the same.
I may be wrong as I'm only just starting to look into this but :
1. In the above picture where the batteries are linked in parallel the total voltage is still 1.5V BUT the amount of Ah (amp hours) is increased. So if one battery has 3Ah (ie it can supply 3A for 1 hour), then if it is linked with the other batteries (4 in total - in parallel) the Ah is increased to 3Ah x 4 = 12Ah
2. If the batteries are linked in series you add the voltages together (so you get 6V) but the Ah stay the same at 3Ah in total.
If this is wrong I'm sure someone will say and I hope they do if it is as I would not want you getting misinformation.
Tony, I'm going to (respectfully) disagree. Steve (the other happy one) is correct. If you have 4x 3Ah 1.5V batteries connected in parallel, you have a 12Ah 1.5V battery. If you connect 4x 3Ah 1.5V batteries in series, you have a 3Ah 6V battery.I just read this and you’re wrong. Ahr doesn’t even enter in to series/parallel calculations.
4x3Ahr = 12Ahr no matter how you connect the batteries. Think of it as a gallon of water. You can pour it in to numerous containers, it’s still a gallon of water.
The Ahr is the batteries capacity to store power.
Back to the batteries....
They are described as "3Ah" and we know they are 1.5V. So the total energy stored in each is 1.5 x 3 Wh = 4.5Wh (= 4.5 x 3600J = 16.2kJ). However you connect them up, the total amount of energy contained in 4 batteries is 4 x 4.5Wh = 18Wh. (4 batteries x 3Ah x 1.5V).
4 batteries in parallel, you have 1.5V. 18Wh / 1.5V = 12Ah.
4 batteries in series, you have 6V. 18Wh / 6 = 3Ah.
Hope this is helpful![]()
Oh aye, agreed (assuming the same resistive load).Yeah, but you're driving 4 times the current through a load with the batteries in series than parallel.
i.e. 4 x Power
The Ahr is the same for both configuration, just that the batteries will last 4 times longer when in parallel.
No, for the parallel configuration you've got 12Ah at 1.5V (=18Wh) and for the series configuration you've got 3Ah at 6V (=18Wh).
This confusion is just because the term "amp hour" isn't complete, as it assumes a certain voltage.
(Similar confusion arises when you say, "This is a 1kW [resistive] heater." It's only 1kW at the intended voltage (eg 230V). If you run it at 115V, it's only a 0.5kW heater.)
'n' batteries have the same 'AmpHour' capacity whether they are connected in series or parallel.
I'm sure I'll agree with it. I think in your case (and Tony's) it's more about semantics than fundamental understanding.I'll bung my proof up later!
True dat.It's a brave man that challenges Tony!!!![]()
Well of course each "cell" remains a 3Ah 1.5V battery. Unconnected you have four 3Ah 1.5V batteries. Connected in parallel, you have a 12Ah 1.5V battery. Connected in series, you have a 3Ah 6V battery.
True dat.
Had to grow a pair some day, though...![]()
What's wrong with his statement about the 1kw heater?
Brain mong!
Before you all carry on bickering, have a look at two definitions AHr and AHrV.
